wakarimasen
Hello folks,
Having finally worked out how to 'snap' the invercone into my meter, this morning I did so and popped the glass in front of the dial back into the case. Now it pressing back onto the needle which doesn't move at all! Does anyone know how to open one of these meters?
Best regards,
RoyM
Best regards,
RoyM
davies24
I did exactly the same thing with my Weston. Couldn't figure how to open it so used a kids toy (one of those plastic darts with a rubber sucker on the end) to grab the glass then a couple of dabs of superglue inside the case edge and pulled the glass down until the glue had set (the Weston was facing down, obviously).
colt45
Did the same with mine. Go to http://pheugo.com/camera/index.php?page=westonmtr you will find the disassembly instruction for a master II it is the same as a master III. Be careful the glass is very very brittle.
Good luck
Robert
Good luck
Robert
oftheherd
Colt45 - I just tried your link and got a page not found error. Is it me?
MPerson
Think you need this link.
Failing that I have had excellent service from Megatron for repair and servicing my Westons.
Megatron London then choose Euro-MASTER II Exposure Meter.
colt45
Sorry for the bum link but that is what came up o0n the address bar. the site is called Camera collecting and restoration. The link is under the miscellaneous section on the left of the main page.
Hopr this helps
Robert
Hopr this helps
Robert
colt45
Just saw the post from MPerson. That is the correct link.
Robert
Robert
Ronald M
In USA it is Quality Light Metric in Hollywood, CA. George repaired all my Westons.
Even added IV dials to my V so I could read the thing. It works like my IV that I stupidly threw away in 1980 because the cell died.
The invercone for earlier models 2 is different and does not require force. Cone part 26090 and multiplier 126092 for when the baffle is open for low light.
None of these requires force.
wakarimasen
Thanks guys - it's in three pieces now, whilst I remove the the two layers of old glue!
.....and now back together, zeroed and ready for use tomorrow
