what´s this?
jjanek
8:06 PM
I have found in auction Summitar 50/2 , it has these spots - is this fungus? Will it get worse? What about influence on photos? And what would be reasonable price to pay?
Thanks everybody
Janek
Hard to tell from that photo. But a few fungus spots are much less influence than a network of "cleaning marks" (scratches) on the front element.
The lens is new enough to be coated. But it's the soft Leica coating. So it's hit-or-miss as to whether professional cleaning will do more harm (lost coating) than good (removed fungus spots).
The shape of the patterns is typical of de-cementing of two elements. There may be also other problems which are not obvious to see from the picture.
De-cementing can be addressed without having to separate the elements, clean and recement. A toaster oven set at its minimum heat for 30 minutes can reset the elements together. Wrap the lens on aluminum foil and keep it standing inside the toaster oven, well lebelled so that when the cement begins to soften the upper lens can set on its own weight over the matching element underneath.
Bring the oven up to heat together with lens and let it cool off in the oven so that there is no thermal chock. Minimum setting will approach 120 to 200 degrees Celcius in most toaster ovens.
I have done it many times with great success. It works best with old small lenses using Canadian balm as cement but failures have also occurred. Do it at your own risk. It is fun.
You're playing a dangerous game here. This worked on older uncoated lens but should NEVER be tried with coated lens...
The spots in the middle just look like dirt. I have some on my Summarit (which just came back from cleaning.) Try shooting a few shots with it - my guess is it won't affect any photos.
