What do you do with 2 film bodies?
Any of the things you mentioned, but usually so I don't have to change lenses. And a backup body is good for mechanical breakdowns or photographer induced damage.
Eventually, you will own several lenses for one camera. And, that camera will go to the shop for repair and you will have several lenses and no camera. With film it is a little more of a necessity to have two cameras because of different film stocks. With SLRs you can have two different bodies, i.e. F3 & F4 with the same lenses. This was an old issue that Hasselblad dealt with when they designed the removable back which held the film.
For me, these days:
- Hexar RF #1: 28mm M-Hex, Kodak BW400CN
- Hexar RF #2: 50mm M-Hex, Kodak BW400CN
They never travel alone, though:
- Contax Tvs: Kodak Portra 160 or 400. (Occasionally 800.)
Plus:
- 90mm M-Hex (in bag)
- HX-18 flash (in bag)
- Sundry photo stuff (pocket tripod, cable release, lens cleaning cloth, etc.)
This is the standard-issue setup whenever picture taking is foremost on my mind (or at least pretty close). Easy to take along, which was part of the plan. (When I'm traveling, I bring the Nikon P6000 and Nikon SB-20 [for the Hexen] and SB-400 [for the P600] along for the ride. Best setup I've ever had.
- Barrett
My everyday equipment consists of two RF bodies. One of those with CV15+viewer attached, like a fixed lens RF. The other one for the other focal lenghts. It is definitly the FL which keeps me carrying more than one body.
Since decades, the same ISO 400 film on two bodies; the M3 with 50mm and the M2 (or M4) with 35mm. Street demands readiness to respond promptly.
M3 with 35mm Summicron with goggles.
M6 with many lenses.
Hexar with 28mm to 50mm lenses.
Standard Leica with 21mm lens
Three films; slow B&W, fast B&W, color transparencies. In B&W, I have cameras for home and for work, so that makes 5 active cameras, but I usually only carry one at a time. On trips, though, I'll grab the color camera if I don't take a digital.
Just curious what you guys with 2 of the same or similar camera use the second for.
Do you use it for a different speed film, different focal length, or maybe one for color and one for black and white?
I use the secound body for backup in case the first body breaks. Mostly I am down to Tri-X and black and white. No excuses.
I rotate between my two M6 bodies. I like having a backup body because I use my camera daily.
When both are out, my MP and M2 sport different focal length lenses, both B/W. Sometimes one of them pushed 2 stops.
And also when one is in service, the other one acts as a backup.
Always having a loaded body is a good reason. very often the same [film]
Screw-mount Leicas and Zorki.1's are the same size and very similar configuration so carrying/using 2 or more is pretty simple. I have a small bag that comfortably carries 2 bodies + lenses w/different focal lengths. But a few times (when I've spent all day in a large crowd) I've just taken the 35mm lens + body and loaded the bag with 3 extra bodies carrying the same film. No reloading.
Tend to have slide film in one, faster negative film in the other. This means I sort of have daytime/evening cameras. The range finder is the evening camera. My other camera is also somewhat cheaper than my Leica, so it's good for taking anywhere and not worrying too much about it.
