I think, the best idea, is to do a test for yourself. I did this, for example, with Tri X in D76 a long tiome ago, and I saw, that it was not worth the while, as at 1+3 the tonality started looking worse, without any appreciable positive effect of other kind. However, this can depend on the developer. Generally, the manufacturer will tend to give you a slightly TOO concentrated "normal" dilution, for the sake of making you spend more, and perhaps control the grain better. I have normally found, that developing at TWICE the basic dilution (D76 1+1, Rodinal 1+50, HC110 1+50, DD-X 1+8, etc, gives you the optimal compromise.
