Leica LTM What is this CZJ lens in LTM?
dexdog
2:51 AM
This serial number shows up in Hartmut Thiele's book of CZJ lenses as being produced in 1939, mostly in Contax mount, with a note that says some were made in Contaflex mount. I have not seen a lens like this before, assume that it was originally in Contax mount and later hacked into a leica LTM. Any thoughts?
https://www.ebay.com/itm/28492275473...Bk9SR9jWg4XpYA
Summar focus mount with the Sonnar hacked into it.
Check out the IR index at F2. DOF to F2. Smooth finish, not serrated like the Summitar.
The J-3 mount is better suited, has correct DOF scale and the barrel screws right in.
So, the auction is for rare and extremely hard to find BS :D. Happens a lot on eBay. Looking at the pics, appears that the rim of the lens is dented and probably will not accept a screw-in filter.
Ya know, this lens might sell at this price, it is pretty at least. It appears to be a real CZJ lens and if the lens conversion was done well, it would likely be a good performer. I say this only because a lot of ZOMZ J3s lenses made from 1957 to 1961 coming outta Ukraine have a buy it now price of about $300.
The filter rings are not too bad to straighten out. I successfully used an expansion type tool to fix the rim of a 1934 5cm F1.5 Sonnar, now takes filters and hoods.
I have a Sonnar "T" very close to the one shown.
I recently mounted a 1952 KMZ J-3 that was on Contax/Kiev mount to LTM using a KMZ focus mount. It has perfect glass and is one of the best J-3's I've owned. Every bit as good as a Wartime Zeiss Sonnar.
Good thing that you had a KMZ mount in LTM, those are getting scarce on eBay. I have a couple of really nice KMZ 1956 J-3s in LTM and one really beat to hell KMZ 1955 in LTM. Saving the 1955 LTM mount just in case I need parts
Ended up selling for $755.00 USD.
I saw this when it was listed and was disappointed to see it falsely advertised by what appears to be a legitimate camera store. I just hope the buyer understood what it was and just wanted it for the convenience/curiosity.
Given the price that Skyllaney gets for LTM converted 5cm F1.5 Sonnars, I'm not surprised.
My conversions would probably get ~$1,000. I would not sell them for that. Compared with the price of having the front and back door replaced on the house, cheap by comparison.
How about just the back door. I would be thrilled if it were only $7-800. Sadly not! ...If you can't tell, this is something currently under way in this household...
