What the Helier 15mm can be capable of >
pizzahut88
7:14 AM
The Helier 15mm is not to be underestimated!
The lens is not expensive, comes with a viewfinder, small and light, easy to carry along as an extra . . . and yields results which could be quite surprising!
http://viking-manfred.blogspot.com/2007/03/gps-n22-1-42-e-114-9-311.html
So I think for any Voigltander user, getting the 15mm is a must if you are not going to get the 13mm, or unless you have enough bunnies to get the Zeiss 15mm!
Manfred
A stupendous shot! On my screen I don't see any converging verticals. Were you actually able to position the camera to avoid this, or is it a photoshop fix?
Again. a shot to be proud of.
looks great!
If you position the camera so the film plane is vertical, you shouldn't have any converging verticals in the image. It's when you point the camera up at a building that you get that.
If you also rotate the camera so the 36mm frame edge is vertical you can get more of the sky scrapers in frame but you can only use a 18x24mm frame so the lens does not apperar to be as wideangle, sneaky.
Noel
A shift lens would have done the same thing.
And you'd need a 15mm shift lens to take that image unless the frame was narrowed. I've never seen a 15mm shift lens for sale, am I missing something?
Actually, the tall building is becoming less and less sharp as you get to the top. I am not sure that I would be surprised by that result.
