What would cause this flare?
ywenz
5:41 PM
Chicago
Notice the darker blacks on the left side compared to the right side? What would cause this? I was thinking it could be a light leak in the body? I processed the film (TRIX @ 1600) myself in Diafine, could this be caused by my bad processing technique? I've seen the same effect several times with different rolls with the same lens+body combo. (M6+CV 35 PII)
For this shot, the only light source was directly above the table...
thanks
only thing I can think is that the light reflected off the dark shirt closest to you has less distance to cover, so doesn't fall off as much.
But I am probably just mis-using the inverse square law.
I'll be curious to hear others thoughts.
edit... could also be a subtle veiling flare from the oblique lightsource? were you using the hood?
dunno... it's a puzzlment.
