what's the current need for full frame?
None of these are relevant of course, with lenses that are natively 'full frame' for APS-C such as with Joe's Fuji kit, which has fast normals, and fast wide angles (both of which are superb lenses, easily in the Leica/Zeiss league.) And there is no M9 or MP so no compatibility needs. :)
Eminently true. But equally, the phrase 'full frame' is meaningless except in the context of, well, full frame -- normally taken to mean 24x36mm.
Enlargement size has jack sh*t to do with the source negative. Experienced darkroom people have that figured out already. Resolution-freaks don't.
Not all about pixels. Not all about resolution.
Yes, but the inverse is not necessarily true. There are upper limits to an enlargement that make higher resolution source material (regardless whether bigger film/sensor sizes or finer grain/higher pixel density) a requirement for bigger enlargements. If you don't raise the viewing distance proportionally, that is. The latter lets billboards get away with medium format where high detail mural size exhibition prints may need more than the resolution of smaller large format sizes.
I agree to most of what has been said here.
There were two main reasons for my yeaning for an EOS 5D some years ago:
1. The chance to use really wide lenses. (I had a Tokina 12-24 for my 40D, but the Sigma 15-30 on the 5D is considerably wider.)
2. The chance to use my "old" manual lenses with the same image angle they were meant for. ;)
Meanwhile, my 5D mainly lives in my cabinet. Because:
1. You get all the focal lenghts for APS in excellent quality.
2. The old lenses are also very good on APS and you get used to the changed FoV pretty fast.
I use both FF and APS-C cameras in addition to film gear. A FF digital produces less DOP than a film camera with the same lens. An APS-C camera with an equivalent FF lens produces more. APS-C cameras cost less and a few lenses are good. FF sensor cameras cost more and there are more lenses to choose from especially if you like primes (I do).
The APS-C image quality is so good now that if you're not printing big (I print) an APS-C will serve most needs - I'm talking work gear. I use APS-C gear for most of my work. FF is used when necessary and for some non film personal projects.
Would you be able to explain the reason for this, please? Is it to do with a digital sensor having less tolerance for depth of focus errors than an equivalent frame of 35mm? If the actual proportions of the formats are the same Ie. 36 x 24mm, I would have thought depth of field would be the same, whether a lens was attached to a digital or film camera.
TIA,
Brett
Image quality and dynamic range.
There is a certian look that full frame has that cant be replicated.
Can you tell on your LCD monitor? IQ, DR, and all that?
Always the limiting factor.
Anything digital can be replicated. That's the whole point.
I think when we're hobbyist, as most of us here are, there is no *need*, only *want*. Some people need full frame, or for that matter medium format (film or digital) for a look they want to get, or a resolution the client demands.
Some companies make stuff for the passion of it, I doubt Ilford makes black and white film in custom ULF sizes for the exorbitant profits and sky-high sales figures. 99% of companies make stuff for money though, and the only reason companies like Sony, Nikon and Canon are making full frame cameras to sell to hobbyists is to make us think we need them, and make crop factor cameras look old hat and rubbish.
That said, as hobbyists, the idea of using lenses for their intended focal length, the 'look' of larger formats, and the plain old pleasure of having something new and high tech may be all part of the hobby.
I'll predict that entire industry will phase out APS-C sensors in enthusiast cameras soon enough though, as making the most popular enthusiast format seem obsolete will be very profitable in new sales.
Not due to any magic difference between film and sensors, nor by specification - at any rate I haven't yet run into any book or official document that defined a smaller CoC requirement for 24x36 FF than for 24x36 film. But in practice, higher resolution digital sensors exceed the resolution of film, and are accordingly often used for applications that once were a domain of medium format or small large formats, so many practically use them at a smaller CoC than standardized.
FWIW, this is also true of APS-C size sensors - where these fill the role of 24x36 film, you won't be able to get away with APS or 110 film CoC definitions.
The use of full lenses at the intended field of view and purpose they were designed for, is the only draw for me. Everything else is a wash for me.
I personally don't need a FF digital camera to make the 8x10
prints I want.
There may be technical reasons that make FF "better" than APS,
for one reason or another, but today'a APS gear is not limiting me in any way.
Not by specification - at any rate I haven't yet run into any book or official document that defined a smaller CoC requirement for 24x36 FF than for 24x36 film. But in practice, higher resolution digital sensors exceed the resolution of film, and are accordingly often used for applications that once were a domain of medium format or small large formats, so many use practically use them at a smaller CoC than standardized.
Isn't that like saying "In practice, motorcycles are faster than cars". Certainly, most stuff you see on the web shows digital out-resolving film, but if you look, you'll find stuff showing the opposite:
http://www.twinlenslife.com/2011/01/digital-vs-film-canon-5d-mark-ii-vs.html
Of course, digital will pull away dramatically as the ISO goes up, but that is a limitation of film. In the same way digital is limited by the size of the sensor, whereas film can just be cut to the size you want.
I agree that in most cases, comparing the same sensor/film area, you'll likely get more resolution out of digital in 90% of cases. But by doing that, you're binding film to limitations that it does not actually have.
Joe, what this means is you are transcending the form and working more directly with content. This is central to successful photography.
I'll paraphrase Bill Pierce: "W. Eugene Smith made incredible images with lenses that most of you guys would turn your noses up at."
The same goes for sensor size. Yes, if you compare simple technical image quality, bigger is almost always better. But the picture ain't necessarily about image quality. (See Eugene Smith...)
Content always trumps form. Always. Anybody who says that picture A is better than picture B because the format is larger/contains more data is an idiot - technically speaking.
The proof for that is the technically excellent picture without content.
Good photographers have always concentrated on content. They extract the best technical performance they can out of the tools that they have. After all, one can always find "better" or "more technically capable" formats/cameras, etc. That's endless.
But without content....
Excellent. You've summed up my thoughts much better than I possibly could.
Image quality. If I could use a pentax 645d or a leica S2 I would, because their bigger sensors are simply better.
I've had some FF cameras. For my purposes, and through much trial and error, I find the Fuji X-Pro1 at 16mb has enough horsepower for my purposes. The system is lighter to carry and transport than the FF equivilant and it lacks some of the troubling bad points of my last FF camera (D600).
I think full frame is still useful for comparing equivilant focal lengths of lenses. With all the formats now existing it's nice to have a standard reference.
Larger sensors are not always better. This is a false generality. It has to do with the fact that the technological advances in sensor semiconductors moves at a far more rapid pace with APS because the market volume is far larger. For the same reason, Apple switched from PowerPC to Intel a few years ago...market share drove technological advancement...they were getting left behind in the CPU wars as the Intel production was far larger. Now, they use the exact same semiconductors so they are on the same playing field and winning in other areas...
It's like saying "more expensive sports cars are always faster." It depends on which specific sensors (or cars) are being compared.
As far as viewfinders in DSLRs go, yes, "in general" a viewfinder in a 24x36 sensor camera is a lot nicer than those in crop DSLRs. This doesn't apply with the Fujis of course.
i used to pine for a full frame digital camera...not so much anymore!
the biggest reason was having a lens and using it as the focal length it was born at...not a 40 being a 60 etc...
but then i realized that my 40 still looked great as a 60 and i just learned to visually compensate for the change and carried on using it.
now, with owning a fuji camera and using the 'native' fuji lenses, the 'need' for full frame seems to have completely disappeared for me.
in fact, i started using old manual focus lenses for fun/play! my 100 is now a 150 and i enjoy it.
i get plenty of limited dof with a 35/1.4 lens...
the image quality is fine, detail is there etc.
not sure why i need full frame?
I am not sure why anyone thinks about anything gear-wise anymore. For the past few years, I subscribe to the wisdom from Thorsten Overgaard regarding gear....Use the camera you love! Simple.:D
Yep ...that sums it up for me too.
Sensor technology is always developing. It's tough to say this, but the dynamic range of the latest APS-C sensors far outstrip the M9's ancient CCD. You get a bit of extra "tonality", but when it comes to tortuous post-processing, the difference is quite apparent.
One of the reasons older APS-C camera could not compete with FFs was because Canon and Nikon didn't take the former market seriously enough. Canon has been using the same sensor from the 550D to the new 700d, over a period of (oops)4 years. During that period it refreshed its FF line twice, and the 5DMKIII is vastly better than the 5DMKI in almost every way. But now Sony and Fuji have GREAT APS-C sensors (NEX6, Xpro1), so except DOF and FOV, there really isn't much reason to go full frame. I shoot everything with my NEX-7, assignments, when I work for the university paper, scenery, indoors stills using lighting sets...and it hasn't failed me yet. Will I pay $3k for a FF NEX? Maybe, but after I buy all the glass I want.
"Image quality" is a broad term. Larger film or sensor provides more graphic detail but not necessarily an image more pleasurable to look at. It seems to me that other factors almost always outweigh graphic details (subject matter, tonal richness, etc.). I'm sure the quantity of data provided by full-frame sensors or large pieces of film can be useful for some particular purposes, but certainly don't add more "image quality" all by themselves.
----------Exactly.
