What's the purpose of a hood being vented?
Makes it go faster. A turbo hood.
No, really. They are often vented so that they will block stray sunlight from the lens, but won't block the rangefinder or viewing window from your eye.
Best Regards,
Bill Mattocks
I would have guessed that it is a weight-saving measure but am curious myself....
Translation for ex-colonists - a 'fag' is a cigarette in Britain. Very different meaning from stateside.
Much like being told by a friend that he'd pop by and knock me up in the morning. It was a bit of an eye-opener.
Best Regards,
Bill Mattocks
I have always believed it was to not obscure the viewfinder ... but the Leica one for the 50mm Summicron looks like it would grate cheese quite well. Has anyone tried?
But not always- some hoods, for instance the Heavystar hood for 50 mm lenses are vented whilst clearing the viewfinder. There it seems to be for "design" purposes
The hood also works on 35mm lenses, where the lower right of the VF would be completely blocked without the vent, at least on a 0.72x finder. The hoods are generic, sold by filter thread and not by lens - Heavystar (or americaneagle or whoever) doesn't know which lens and which body you'll be using the hood with.
I always thought it was so you could turn a circualr polarizer, my old mamiya had a vented hood area that wasnt even near where the veiwfinder was being blocked off
Yes, the vents are there to (mostly) keep out of the VF's way. On my Konica Hexar RF's 28mm f/2.8, the vented hood "pivots", allowing the photographer to adjust the positioning of the vents for minimum obstruction. Can't imagine they were the only ones to think of this.
- Barrett
The vents are so the camera does not slow down too much due to wind drag as you swing it in a rapid arc at the end of its strap towards the fat head of a guy who asks you what a vented hood is for. Also, it is a whistle. Whistle while you work, that's it.
Best Regards,
Bill Mattocks
