Corto
For a Voigtlander Vito CLR........:bang:
rbiemer
Unabashed Amateur
Corto,
According to the manual (see here:
http://www.butkus.org/chinon/voigtlander_pdf/voigtlander_vito/voigtlander_vito.htm and scroll down a bit 'til you find the CLR file. )
The filters for the CLR are "32mm push type filters".
Which is not a common size any more but not the hardes size to find either!
I would start here:
http://stores.ebay.com/photo-widget/32mm-push-fit-hoods-filters-/_i.html?_fsub=4725346&_sid=7972797&_trksid=p4634.c0.m322 This is a seller I have dealt with before and while not the cheapest, he packs well and ships promptly.
Currently he seems to have more hoods than filters but that does change.
Good hunting!
Rob
I would start here:
Good hunting!
Rob
Corto
Thanks! Good source.
Ken Smith
Why yes Ma'am - it folds
You can often find the Voightlander 32mm push-on kit with a lens hood and several filters that come together in a leather horseshoe case. If you don't see them listed for Vito - search under Perkeo since they both use the same filter size. Voigtlander also sold them solitary in the blue and clear plastic Voightlander cases. Zeiss also made 32mm slip-ons for their folders. And then theres the Agfa marketed 32mm slip-on filters for their 120 folders. All of these will work with any lens sized for 32mm slip-ons.
mike-s
Try here www.mwclassic.com
rbiemer
Unabashed Amateur
Corto, you might also contact Collectible Cameras in Arizona.
See here: http://www.collectiblecameras.com/
Very good folks to deal with and worth an email or phone call, I think.
Rob
Rob
