dlofgreen
Okay, so I have been looking all over to find the little pliers with the points on them to get the asa dial of of my GS. No luck
. I have been to the auto parts stores and all of the snap ring pliers have points that are too big
. Nothing even close at the local LowDepot. Any ideas? What do you guys use to get this little bugger off?
D.
D.
JasonC
dlofgreen
Thanks JasonC, I was kind of hoping I wouldn't have to spend twice as much for the tool as I did for the camera. Any body else have some creative ideas before I drop $35 on something like this?
JasonC
I also remember reading somewhere in the forum that someone files down a pair of needle point pliers for the dial.
Jason.
Jason.
dlofgreen
That's a good one. I have a pair that I can do that to if I have to. Other ideas?
I have used a pair of needle nosed pliers for a "fine spanner". For the ASA dial, I have used a pair of stiff metal tweezers.
P
pshinkaw
Guest
I note that you are in Colorado. There is a Harbor Freight retail store in Aurora/SE Denver. They have inexpensive tools like small needle-nose pliers and tweezer sets for only a couple of dollars. They are easily ground or filed into other uses.
-Paul
-Paul
dlofgreen
Grayhound man that is perfect! That is exactly what I will do. I may try the stiff tweesers too.
pshinkaw, thanks for the heads up on the cheap tools. Unfortunatly I live just outside of Boulder so it would take me two hours round trip to get over there and back. I may sound a little lazy but after living 12 years in SoCal I can't stand driving any more than I have to.
dlofgreen
Thanks for the warning, I have heard they are very fragile.
surlysimon
popitz
The Rangefinder Junkie
greyhoundman said:Warning Will Robertson!Don't try tightening the screw very much. It's brass and snaps easily.
i learned that the hard way with the wind lever of my GT. :bang: for the ASA dial i just use tweezers.
dlofgreen
Okay I have the dial, advance lever, and the rewind post off of the camera (thanks to a few doner tools and a dremel). Now I thought "great only these three little screws left". What a pain. I had to modify a little screwdriver with my dermmel to get it small enough for those little buggers. Now they won't budge! What is the best way to get these things loose?
dlofgreen
Just bumping this one up. I really need some ideas.
KoNickon
Nick Merritt
This is a fortuitous string. Last night I was trying to use tweezers to remove the advance lever on my Lynx 14e, but they twisted way too much. Yashica Guy recommends getting snap ring pliers, and I'll check that out, but using a compass as surlysimon's link suggests may well do the trick, and probably for a lot less money, like $10 or less. I'm off to an art supply place tonight to check them out.
Try putting a little Isopropyl Alchohol, Ronsonol, or even a little nail polish remover to loosen up the screws. This was not a problem on the 3 Yashica's that I hape opened up. A well fitting flat-head jewelers screwdriver did the trick. My Nikon SP's gave me trouble. I ended up using an exacto knife to carve a new slot in "the last one".
P
pshinkaw
Guest
On stubborn screws, I start with a tiny drop of denatured alcohol or Everclear. Give it a chance to soak in, then use the screwdriver to apply a little torque in the "tightening" direction. Then reverse the torque toward "loosening", and the repeat. This can help "break the screw loose". If it doesn't work, elevate to the next stronger solvent, Ronsonol (petroleum naptha) and go through the tighten-loosen sequence again. If it still doesn't work, Use fingernail polich remover "very" sparingly and repeat. As a last resort use Liquid Wrench and let it sit overnight or longer before trying again. I use Liquid Wrench last because it tends to spread lubricant around and doesn't evaporate as fast as the others.
-Paul
-Paul
dlofgreen
Thanks guys I'll give that a try and see if I can't finally get this cracked open.
john neal
fallor ergo sum
One other thing that might work is to touch the tip of a small soldering iron onto the screw head for a few seconds, then apply the easing oil - the thermal contraction helps to draw the oil into the threads. Just be careful not to fed in too much heat and discolour anything.
And remember that all of the fluids mentioned are Flammable and produce a lot of vapor. Be careful around the soldering iron.
R
Rob
Guest
I use snap ring pliers with the tips ground to a point. I have use a drawing compass with filed down nails replacing the pencil lead and pinpoint. Got to be careful not to scratch it.
