D
Deleted member 65559
Guest
"eins"?
"eins"?
I have eight different green filters in order to fit different lens' thread sizes. I assure you that, while green is green, green filters vary quite a lot. And there's also "yellow-green" as a filter type... 😉What do you mean by “completely”? After all, green is green…
Which is why it's important to test filters, just like it's important to test everything else.
G
... and that’s why I was curious by your testing methods and results. ...
If you haven't already sent it back... you might not need to.KEH sent me the CV Heliar LTM nicely packaged , even with the hood screwed in. However, the hood cannot be unscrewed. It is being returned. I will have to wait a log time for another one that isn't 550$ or more these days brand new and even on ebay.
I did send it back and I started with even force . I suspect someone, perhaps the previous owner cross threaded when used. I decided this was KEH's issue. I have to admit KEH consumer service is pretty darn good.If you haven't already sent it back... you might not need to.
If the 40mm Heliar is anything like the earlier 21mm Color Skopar, the problem might be the hood itself. Trying to force the hood off just bends it out of shape, making it near-impossible to remove. The key is to be surprisingly gentle and even with it - any force that may contort the hood even slightly will cause it to bind.
Exactly..... a rubber band around the circumference allows for a light grip..... or a gently cupped hand over the front of the lens, worked for me every time.If you haven't already sent it back... you might not need to.
This is not an exact answer to your specific question, but here is a list of filter threads.what is the thread pitch on the CV Heliar 40mm? .5 or .75
rangefinderforum.com
Damn, thanks for the explanation on the 21mm Color Skopar hood. That explains why I could never take the hood off mine and just gave up and left it on.If you haven't already sent it back... you might not need to.
It still catches me out from time to time when I want to remove it to put a filter on. I just picked up mine and tried to remove the hood as an experiment - it took me three tries to remove it instead of unscrewing the lens!Damn, thanks for the explanation on the 21mm Color Skopar hood. That explains why I could never take the hood off mine and just gave up and left it on.
I just took a look at my 21mm, and its so strange and counter to the usual way of unscrewing a lens hood, but using your method, the hood came out without an issue. Thanks again.It still catches me out from time to time when I want to remove it to put a filter on. I just picked up mine and tried to remove the hood as an experiment - it took me three tries to remove it instead of unscrewing the lens!
I do love Voigtlander's lenses but every so often I run into something like this and wonder how on earth no one realised there was an issue.
Would it be possible to swap the glass from an A36 filter into a 34mm UV mount? 34mm UV filters are readily available- Jack the Hat lists them.
