ferider
Hi Mike,
two comments:
- on your first post you mentioned RF misalignment. The reports that you usually read are about the R3*; most R and R2* users are very happy. (I have used R, R2, R3a and T and only had alignment issues with the R3a myself).
- if you don't mind external finders so much, consider the Bessa T as well. It is M mount, more robust and quiet than the R, and your 25 comes with an external finder and could be the primary lens. It usually costs about as much as a Bessa R, you will not need adapters, but you will need finders. Maybe the Helios 35/85 finder will work for the beginning. The T also has enough EBL to focus a faster 90mm.
Good luck,
Roland.
two comments:
Good luck,
Roland.
