Which HC-110 dilution for Ilford Delta 400?
p.giannakis
Pan Giannakis
4:02 PM
Stafford - UK
Hi all,
Managed to get some Ilford Delta 400 cheap so I will be shooting them soon. I am a long term HC110 devotee so I am wondering which dilution to use. Ilford suggests B but has anyone tried any different? Please post pictures also if you have.
I would use the dilution you are familiar with and base the time calculation roughly on Ilford's recommendation of dilution B. Do a test roll and see if anything needs to be tweaked.
I used dilution H with HP5+ for years but can't remember if I used any Delta films...
This one is Delta 400 in HC-110 Dil B for 7.5 mins, from a 6x4.5 negative. If developer temps had dictated dev times of 5 mins or shorter, I would have used Dil H to extend the time. I've been pretty happy with HC-110 for most films, occasionally using D76 or Rodinal in some situations.
[/IMG]
Thanks everyone,
I shot a roll some time ago and developed it at 1:50 for 11 minutes but i wasn't happy with the results. Almost the whole roll cal out like this - quite muddy greys (and I have adjusted the highlights on GIMP on this one).
That may be the case for the old FX39 but the FX39II that is now available is much better - I've not had problems with it open for 3-4 months, but once it looks like finely aged Rodinal it is past it.
When someone says that they used developer XX and it gives bad results so they went back to developer YY, almost always what this really means is that they didn't take the time to find the correct dilution and time to get the results that they want.
HC-110, 1:50 dilution, 11 minutes @ 20, agitate 1 min then 10 sec every minute, gives me results that work for me.
I'd post an image but this board is so antiquated that it won't take it and I'm not playing the old 'post somewhere then copy link to embed' game.
