Who does your E6 processing?
Thanks all for your responses....there are some good options. I have never used anyone but my Phila outfit. That will change.
There is one lab in Philly that still does E-6, and they charged a lot ($20) the one time I had it done.
I just started doing it myself with the Arista kit, very happy with first results.
Randy
Thanks for the info.
Unfortunately, I cannot find Kuzano's post with the pic on how to fill out the envelope. In any event, I will check out the local Walmart tomorrow to look for the magic Fuji Kiosk. If it exists, my 6x7 will get a taste of C-41 color:)
Here are the previously posted SEND OUT ONLY pics
I am posting the envelopes as filled out for the Fuji Kiosk/Drop slot on Walmarts "SEND OUT ONLY" system. The envelopes will be Fuji, with a Fuji telephone number on them. The lab will be Fuji for C41. Fuji will arrange E6 Processing.
As far as I know... No scans, I doubt if push/pull is available. I simply have them processed and sleeved. They will cut and sleeve, or they will sleeve the whole roll uncut and roll it in a tuble. The tube is pretty tight, so my preference is cut and sleeve.
I wish you luck. If you don't locate a kiosk, ask in what would be a photo department (usually near electronics) what they are doing for SEND OUT ONLY processing. That should be the Fuji Kiosk, unless they are collecting them at a counter. In any event, you fill ou the envelope, seal it, and keep the tag. Walmarts program whereever I have seen it is that they always call the customer on return of processed film. It should still be in your original envelope, sealed when you pick it up. The price is placed on the envelope by Fuji at the end of processing. The store does not price the processing.
You can do this at Rite-Aid with the envelope filled out the exact same way. I write:
"120 film, C-41 process, 3x5 prints, cut and sleeve negatives."
Cost is the same as Walmart (less than $2 per roll). Turnaround time is about a week or so...
