Beemermark said:
it's arbitrary because why pick 1? So why is my 35mm Elmar labeled 3.5/4.5/6.3/9/12.5/18. Why at some point did Leica Change to 1/1.4/2,etc?
Was there a standard, code or other international ruling body? I don't think so, or at least I never seen one.
Just asking. It probably started to become standardized when the ASA (American Standards Association) promulgated standards for determining film speeds.
If someone can point out a Country specific or International Standard (such as ISO) then I will agree it is not arbitrary.
Basically all you're quibbling about is what constitutes an "arbitrary" agreement.
You are saying any agreement is arbitrary until a standards body is involved. In your logic, standards bodies alone have the power of conferring non-arbitrariness. According to you, everything is arbitrary until someone puts a stamp on it, and the word "arbitrary" is synonym of "not really official", "not officially endorsed by the right people".
Roger and others are arguing that the f/stop system expresses a ratio between two lengths, and that 1 is a mathematically special and beautiful ratio. Consequently, denoting your stops so that they start with 1-1.4-2 is less arbitrary than alternatives such as 1.1-1.6-2.2 on the same series.
I would tend to agree with the latter, because standards bodies, while useful, are basically glorified labeling institutions, while the elegance of the latter system comes from the underlying mathematics of the system itself.
The reason Leica put the 3.5-4.5-... scale on early Elmars is, as Sevo has pointed out, that Leica just took the open aperture 3.5 and then full stops from there. The disadvantage of this system is that you end up with different f-stop series on all your lenses, depending on their starting apertures. That's why Leica eventually switched to the system everybody else was using.
