f16sunshine
Moderator
Sony has a problem and it's an Apple although not the Fuji variety. 😉
How do you mean - Raw support or other?
It appears (at least from the rumor mill) that Fuji will produce a consumer version of the X-Pro1. This camera will have not have the hybrid viewfinder but an EVF and LCD, maybe some sort of image stabilization in the body, a built-in flash and the 18-55mm as the kit lens.
I'm not sure there will be an X200 yet, (the enthusiast version of the XP1 will be first) though when it does come it will probably be an evolutionary product. They will move the buttons around and improve the operation, make software changes and put the x-tran sensor in it. Will they change the lens is the question - maybe a fast 35mm.
The zooms, 'meh' and are unlikely to spark much interest except with the enthusiast. I'm not sure zooms are going to work well with this version of the camera. Fuji has hinted at them being relegated to the EVF. I've also heard them indicate that to use the OVF you would set the lens length in the menu (meaning for every focal length) and then take photos which seemed very cumbersome. I'm not sure they settled on a method until late in the design process. I betcha that means folks will have 'issues' with the implementation.
How do you know this intheviewfinder?
It may, and I could be totally wrong, but they'll need to nail the implementation. I'm not so sure it will work well with the current software.I think the 15-35/4.0 zoom will sell a great deal.
I think the 15-35/4.0 zoom will sell a great deal - I bought the X-Pro1 for its primes, but intend to also use it as a back-up for my FF camera - and using the zoom on a tripod with the LCD would be great for landscape photography. After all, primes are great for handheld photography, where framing is not always critical, whereas landscape demands perfect composition - and to get that you first get your perspective by placing yourself relative to the subjects, then do the framing with a zoom! But maybe I am to enthusiastic...
Now to see if I can convert that 23/1.4 to my Nex E-mount. 😀
Because Fuji has a long camera tradition and Sony is high volume consumer oriented.
Why not just use the Sony/Zeiss 24/1.8???
Well, that's one way to do landscape photography. But some pretty famous landscape photographers (e.g., A. Adams) managed to work without zoom lenses.
I'm told by a reliable source that Adams's view cameras were set up so that the tilt movements could be set only in 15° increments. Apparently, he viewed the continuously-variable tilt settings available on most cameras as mere concessions to the feeble and weak-minded.
I was joking -- making fun of the idea that if today's superb zooms had existed when Adams had been working, he would have eschewed them. I'm certain that he would have used them; he was a technophile through and through.
