Why there isn't an F/1 Sonnar?
axiom
Non-Registered User
7:12 AM
Any tech savvy can tell me why there isn't an f1 Sonnar? I thought in general Sonnar can go brighter than Planar. There is an f1.4 Planar, why there isn't an f1 Sonnar?
I may be willing to trade my Noctilux for an f1 Sonnar if it exists.
I've never heard of a Sonnar faster than 1.5. And, those are all supposed to have focus shifts. I can't imagine how much wrangling and compensation you'd have to go through to focus it at f1....
I CAN imagine, though, how delicious the bokeh would be if you could get it right....
regarding to the focus shift issue
I think Zeiss has some non-flat type aperture plane to take care of focus shifts
Seriously, I want an f1 Sonnar
In the "Zeiss Compendium," there is a section that talks a bit about super high-speed lenses. I believe the authors (Marc James Small and Charles Barringer) wrote that Carl Zeiss never showed a great interest in pursuing the development of super high-speed lenses.
As I recall, Zeiss felt there were too many optical compromises to make in order to obtain a small amount of speed. (I should look it up to be sure.)
Apparently, the sentiment toward such lenses hasn't changed.
From my point, I've never felt a need to use anything faster than f/1.4 (or f/1.5 for the Sonnar).
There are a number of F0.75 lenses out there for X-Ray cameras, CRT's, etc. You do not need much back-focus. The Rodenstock 42/0.75 is an impressive piece of glass that could barely clear a focal plane shutter in between it and the film plane. For X-ray cameras, or small sized CCD's, it would be fine.
Dear Brian,
And of course small-format (16mm/8mm) movie cameras -- and unlike X-ray and CRT cameras, these are fully colour corrected instead of green-light-only. But hey! Don't confuse people with facts. Surprisingly many people are convinced that the only reason you can't buy a 50/0.7 in Leica mount with full-frame coverage is sheer spite on the part of Zeiss, Leica, etc. Oh: and the reason any lens costs more than $500 is pure greed...
Tashi delek,
I'd rather put my money into film. We have too many folks here whose eyes bug out as gee aye ess morphs into el you es tee.
Over the years I've briefly owned a 50/1.4 Nikkor and a 35/1.4 Summilux, then went back to using f/2 glass.
Fast movie lenses then ?
I guess the Kubrick Zeiss was usable for the 35mm movie format only (halfframe), in that case it may be interesting to check what is used in the movie industry today. Much more expensive than similar lenses for normal 35mm photography they at least exist. And can be used on Micro 4/3 cameras and most likely on the Samsung Micro APS NX camera that will be launched on July 7th. With adapters of course.
T1.3 lenses are available which translates to less than f1.3. To stay on topic there are Sonnars included.
http://www.arri.de/camera/lenses/35_format_lenses/master_primes.html#_blank
On a Panasonic GH1:
http://philipbloom.co.uk/2009/05/12/panasonic-lumix-gh1-in-joshua-tree-and-pl-lenses/
Ernst Dinkla
Ziess did make some very quick large format lenses, like Xenotar 150/2.8 and some pretty fast Tessar of various focal lengths as well.
Not sure what formula Kodak used for their Aero-Ektar's but there some real screamer's... 12" f2,5, 24" f6, not to mention the 7" f2.5 which is respectable chunk of glass, and radio-active as well.
The size and weight of the Master Prime lenses (obtainable from the Arri link given above) give one good clue as to why such lenses aren't suitable for 24x36mm. Even for 18x24mm they are 114mm (4-1/2 inches) across at the front and 205mm (8 inches long) and weigh at least 2.2 kg (almost 5 lb). To cover 24x36 they'd probably need to be at least 150mm/6 inches in diameter, 250-300/10-12 inches long, and weigh 4.5 kg/10 lb upwards.
I couldn't see prices on the Arri link but from memory (I handled the lenses at Oberkochen a few years ago) they were around the $10,000 mark, which means that for full frame they'd be more like $20,000.
At this point, they are not really hand-holdable or affordable!
Note that the Sonnar-type Master Primes are the longer focal lengths, 75mm and upwards; the equivalent of maybe 105mm and upwards on 35mm. At this point you have only to correct across a very narrow angle of view: much easier.
The Xenotar was of course a Schneider design, not Zeiss; the Zeiss equivalent was the Planar. I have had a couple of 100/2.8 Planars. Film location tended to be the limiting factor.
Tasho delek,
OK, from the Zeiss Compendium. I'll paraphrase:
At the 1966 Photokina, several companies were showcasing high-speed lenses, including Canon and its 0.95 optic.
On a lark, Zeiss created the "Super-Q-Gigantar" and gave it an arbitrary length of 40mm and maximum aperture of f/0.33. It was made of a large condenser lens, and the engineers created it in a couple of hours.
Zeiss wanted to demonstrate through humor that the most important aspect of a lens wasn't its maximum aperture but rather the maximum aperture at which a good image can be recorded on film.
I should add that the Zeiss marketing machine -- when it came to Zeiss Ikon -- made numerous strategic mistakes.
I rather like the small size of the f/1.5 Sonnar for the Zeiss Ikon Contax. I've used it at night and haven't felt hampered by the f/1.5 speed of the lens.
