ChrisLivsey
As relative newcomer to Nikon Rangefinders can I add an observation? If you are used to using tabbed lenses to focus take care with the external mount lenses. As you see from some of the posts above they have a spring loaded external lock. It is very easy, for me at least, to mistake this for a tab when focussing at the eye, this unlocks the lens which could then become detached from the mount. I have not managed to do this and am learning to remember.
I have not put a lot of film through yet but concur that the 35mm f2.5 is very good, I of course have a yearning for the f1.8, it is fast, it is legendary and a little voice says expensive and probably at f4 no better than the f2.5 but at f1.8!!
The Voigtlander glass is also very good and beautifully made for 21mm it has to be the answer. You can buy and re-sell for little or no loss to run through the options. I always tell myself that as well but the selling bit never seems to happen for some reason.
3.5cm f2.5 Nikkor Adox 100 Td-201
What flare?? Very resistant and no hood, as said no need, well recessed element.
Voigtlander 21mm Skopar Eastman Kodak 5222 TD-201
