Peter55
Leica M5 & Summilux User
Well this is my question. Will a Jupiter -12 35mm f/2.8 fit and work properly on my M5. I understand that I must use it with a 35/135 Leica M to 39mm LTM adapter.
What I'm worried about is the rear glass element of the Jupiter-12 as it a non retrofocus design and the rear glass actually prodrudes very much beyond the rear lens mount. The M5 has the CDS meter cell which raises as the shutter is cocked, and lowers before the first curtain opens.
I am hoping that with the M to 39mm LTM adapter that this moves the lens outwards by just enough to allow the lens to mount and to work normally without ever hitting the camera's CDS cell or the shutter curtain. I would not wan't to damage my M5, and also I would not wan't to damage the Jupiter-12.
Is there an M5 user who has used the Jupiter-12 without causing damage, if so could you let me know so I can relaxe and order the lens.
Thank you in advance for your help.
I have read that this is a good lens and at the moment I am low on funds so I think this one will work forme.
