GaryLH
That's a good idea, Gary.
I'm changing my method of manual zone focus...that would make it work even better. That certainly works great with 3p lenses with distance marks on the barrels, and should be fine with fuji lenses with the AE button approximating focus.
Thanks for that
Your welcome.
Just in case some things to think about..
CoC for ff versus APS-c is different.. Run a dof calc to double check. Also make sure your adapter allows proper inf focus, otherwise u need to stay with evf.
With some, but not all adapter, u can shim the adapter to focus correctly at inf.
Have fun,
Gary
Ps.. Unless other mirrorless cameras, the heavier xp1 works well here because the heavier slr lenses don't end up feeling in-balanced (front heavy)..
SausalitoDog
Thanks for warning. I do refer to the DoF app on my iphone occasionally, but then in the heat of shooting....
GaryLH
Btw ... Out of about 7 or so different adapters, I have had to shim 4 so far..
Gary
Gary
celluloidprop
I didn't care for the XP1's OVF - w/ the 35mm it didn't look right (compared to the X100 and Leica/Bessa RFs) - somewhat small/distant, almost distorted.
To be real honest, I didn't realize that the XE-1 had an EVF. I haven't been paying attention to the Fuji announcements, I thought this was a LCD-only body. Upgraded EVF makes it more interesting.
GaryLH
Small and distant... Hummmmm.. Not sure if this could be it..
The ovf has a built in magnifier. If u hold the evf/ovf lever for more than a couple of seconds, it moves the magnifier in/out of position.. Gives u a way to decide how much of the field outside the frame line u want to c.
With the mag active, it makes the 35 frame closer to normal film rf ones. I suspect they did it this way to provide frame line room for their 14mm (non-mag mode) that was suppose to ship this quarter.
Gary
celluloidprop
With the magnifier it felt like looking through glasses, almost. Without the magnifier 35mm framelines were fairly useless, IMO.
semilog
curmudgeonly optimist
Holy cow. I thought I knew everything about this camera... had totally missed this awesomeness. Thanx!
Stockman
Absolutely not!
OVF is too useful
OVF is too useful
GaryLH
I missed it at first as well... Got bored one day and was browsing utube videos and stumbled on one about the use of this handy magnifier..
Gary
rasterdogs
No trade here.
I got the X-pro1 for the OVF use it almost all of the time.
Really like it.
I am pondering an X-E1 with the kit zoom as a bicycle riding camera. Need to see how the EVF and the Zoom shake (pun intended) out.
-Rasterdogs
Really like it.
-Rasterdogs
