NickTrop
Answers mostly what I expected and not what I'm looking for. Perhaps I wasn't clear, so let me give an example:
Classic Leica 50/2 Summicron. It's a 7 element 5 group design. Nothing fancy optically. (Ain't talking about new lenses that are imo overcorrected, high element count). Classic Summicron. Very average specs for a 50mm prime. Not super fast, to the best of my knowledge nothing exotic...
The above is a world renouned lens. A "classic". "Special". "Legendary". Going rate? I dunno. Guessing $1,000 for a pre ASPH?
So, here's a list of some lenses in this focal length range:
Zeiss Planar (C/Y) 50mm f/1.7
Pentax (FA) 43mm f/1.9
Pentax (A) 50mm f/1.2
Canon (EF) 50mm f/1.4
Yashica 50mm f/1.4 and 55mm f/1.2
Porst 55mm f/1.2
Zenitar 50mm f/1.4
Voigtlander 50mm f/2.5 Color Skopar
Voigtlander VM 50mm f/1.1
Minolta AF 50mm f/1.4
Olympus OM Zuiko 50mm f/1.4
Pentax-M SMC 50mm f/1.4
So. My question is. For "basic" primes that fall into "basic" widest aperture range, with same or similar optical formula... Apart from build quality and Q/A what is it that distinguishes these lenses optically -- especially considering the cost differential? Everyone has heard of the legendary "cron". Famous photographers swear by it. Old ones command $1,000 price tags. Nobody cares about the Yashica 50mm 1.4. Same optical formula.
Now. I could argue that, perhaps, in the case of the 7/5 configuration, Leica may have crimmped their widest aperture so you didn't get the crappy, flare-y, low constrast, veiled, CA'd output you get when you shoot such a lens at f1.2, 1.4 or at its widest aperture. Just because you "could" create a 1.4 lens at this range doesn't mean you "should".
But one could argue you can get the same results from a Yashica 50/1.4 shooting at f.2 as one could get from a 'Cron. And why is the 'Cron (as one example) regarded as "legendary" and so sought after? What is the technical distinction over a Pentax or Yashica (say) that can be had for $50-60 bucks with the same optical formula?
Is Leica glass "doped"? Is there a technical reason, optically, they're better? Again, I'm talking two "average" non-exotic primes in the same non-exotic focal lengths, with the same (or similar) common elements/groups (7/5, 6/5 etc.) configuration -- 50's say.
Is the glass itself special/different? If so, how? (Again, I'm not talking asph or high index... etc...)
Porst 55mm f/1.2
Zenitar 50mm f/1.4
