Would this lens work on the RD1?
Sure. You'll need an M to screwmount adaptor, that's all. It won't be rangefinder coupled, but that doesn't matter.
With the R-D1's 1.53x crop factor, you will either need a different finder or you'll need to mask off the finder that lens comes with so that it shows a 22.5mm field of view instead of 15mm. I'm thinking about getting a 15/4.5 myself and asked about the finder issue in another thread (here).
A few things:
1) As Sean explains in his wide-lenses review on Luminous Landscape (here), the 15/4.5 vignettes quite badly on the R-D1. I'm prepared to live with that; you might not be.
2) Unless you need something else from B&H in the same order, would you consider buying from Stephen Gandy at cameraquest.com? Buying from him is a nice reward for the immense time he puts into one of the most informative RF sites around -- and you'll even save $4.95 versus B&H.
3) Gandy stocks the best viewfinder for the 15/4.5 on an R-D1, the Cosina Voigtlander 15D (D indicating that it's designed for digital -- that is, it offers a 22.5mm field of view instead). Unfortunately, that finder is $175, and the screwmount-to-M adapter you'll need to mount the lens is another $55. Instead, as the above-linked thread suggests, consider the $128 finder for the 25/4, which is apparently a good approximation of what you need (better at infinity, a little too tight at close focus) or buy the 25/4 lens as well, which comes with the finder for $245. Then you'll have an extra lens, although you'll need another external viewfinder for that one (does it never end?) unless you don't wear glasses. If you're spectacle-free, apparently the outside edges of the R-D1's built-in finder, outside the 28mm framelines, work OK for the 25/4. No matter what viewfinder you go with, you'll need that screw-to-M adapter.
Also consider the CV 12mm lens which, in my testing, performed better overall on the R-D1 than the 15mm.
Sean
The Voigtländer 12mm/5.6 is indeed recommendable. The slight vignetting is a nuisance only in uniformly colored shots (clear sky, snow field) and the click stop at 1m obviates the need for any focusing. (The lens is not rangefinder coupled, along with the 15 and 25mm.) It comes with an impressive 12mm (135 format) finder, but you may want to order the 12D finder for the 1.5 digital crop. I'll be happy to send some sample shots if you want. -Børre
The 12 is fantastic but bloody expensive. I've shot a lot with it - check my flickr gallery.
I may get the 15 as well but the severe vignetting has put me off. Only downer with the lens on the R-D1 is that the aux D finder costs an arm and a leg as well - fortunately I got a good deal on one from here. Its tricky to use on the R-D1 without the D aux finder, although you could tape up the full-frame finder at a push...
