F
former member
Guest
This one is as unsharp and saturated as you can get.
I'd buy one - but only if it was a "special" leica - maybe the King of Siam's Brother in Law's 46th birthday - with a baby seal fur cover and a limited 50mm made of titanium , plutonium, and volcanic glass - for let's say 14,500 dollars us
Software is trivial as you skip the Bayer Interpolation. Cost of inventory and size of the market is the real issue. The advantages, picking up twice the sensitivity for the sensor and eliminating any chance of Color Aliasing.
I don't think software is trivial. The cost of software is usual gigantic for these kind of applications. Not just because it is comex, but look at the M8 how many updates it took to become good, stable and functional.
While I'm at it, what is wrong with the m8/m9 BW pictures? If you want to blow them up to 17x22" you would be wise to use film. You can shoot a lot of film instead of a $10.000 body. And Much better quality.
But for 6x8" a m8 or m9 makes nice pictures.
And I hardly can believe a BW m9.1 would make a wise investment for a professional because the ROI wouldn't be there. There Are (not much) assignements where they pay you double or more to get 13 stops worth of BW pictures. So to me it would seem like a nostalgius camera, but way to limited compared to what a regular m10 would offer in the future. And probably at less than half the price. Or less.
Any digital camera's sensor is essentially a BW sensor in that it is sensitive to all light wavelengths across the visible spectrum (and a little more).I don't get the arguments in this thread. All sensors are designed to respond light wavelengths. There is no wavelength for white or any shade of grey. They are derived from measuring the range and intensity of the primary wavelengths. There is just intensity of any wavelength. So that means any sensor has to interpret what is hitting it and then process that to output. Surely that therefore means the it is the processing behind the sensor that detrmines what the output will look like and not the sensor itself. And that means if the firmware and/or software in current cameras is written to suit B+W film curve output then no special camera is required. And if the firmware and software can do that then so can photoshop or other third party software.
I suspect that most of the R&D and software development goes into colour and B+W is just added as a nicety without trying to mimick any particular B+W film curve.
The suggestion that a special B+W sensor is requireed implies that the sensor would be sensitised to different wavelengths than current sensors. But which wavelengths? Just about anything related to this is capable of being modelled by software so I fail to see why a special sensor would be needed.
This is a 100% crop with my monochrome/infrared camera.
Different - yes - better - no. The same for digital. I wish people would stop comparing the incomparable...🙄(and it is still better than digital)
