atlcruiser
Part Yeti
Hi all,
Just got finished with about 15 rolls from our last trip and I was thinking the scanner was wonky...could not get a very sharp scan... screwed with it way too long then I took the x pan with the 45 on it outside and came to realise the infinty was off.
Anyway to fix on my own or suggesstion on whom to send it to?
gshybrid
David
Are you sure the range finder is adjusted properly... I had to adjust mine.
atlcruiser
Part Yeti
I am not but when I go to infinty the lens is a touch past where it needs to be so that the image is slightly out of focus...very slightly. If I turn back from infinity jsut a touch it is fine. You really cant notice it and I could not tell it was wonky until I started really looking at clouds and such once they were scanned
gshybrid
You should take some shots close focusing with a tape measure and also shoot distant object with the lens set at infinity. If you get sharp images then it's your range finder. If not it's probably your lens. I found information on adjusting the range finder online here... it's very easy for horizontal adjustments a little trickier for vertical. If it turns out you have to adjust your range finder feel free to PM me if you need help... the linked instructions are a little vague in places.
atlcruiser
Part Yeti
I will test it tomorrow..thanks for the link and you ar eright...not all that much info!
My thought is lens...the PICs I am looking at were all shot with the lens set to infinity
atlcruiser
Part Yeti
so i did my test...lens is fine, RF is fine, operator is not quite so fine.
gshybrid
good news... sort of
