Jamie Pillers
Skeptic
Is there any technical reason why Fuji can't update the other existing Fuji X camera models with a firmware update that includes the new Neopan Acros film simulation?
Yes there is a reason. If they do then you will keep your 1 and not get a 2.:bang:😀🙂
It should be relatively easy to simulate the RGB levels to duplicate the spectral response. It is adding the Acros grain structure that would be a bit of a challenge. So from a RAW file you should be able to do it in post. Once you get it dialled in, I would think you could automate it.
You would have to rewrite the firmware and validate it for all the old cameras, assuming it fits in their EPROMs. That's a lot of work. If you send out an update that has Acros but crashes all the time, that would be a PR disaster.
Dante
hasn't Fuji done it already in past, add Classic Chrome etc. for their older models that didn't have them during release? sure it would mean new firmware update. guess Fuji is only camera company that could be hoped todo this, Canon being in opposite side of spectrum.
Based on past releases of Films Simulations, there will be no backwards compatibility. The X-pro 2 starts a new generation of X-Series sensor assemblies (including the IR filter and color-filter array).
However, Classic Chrome was added to the XE-2 in firmware release 3.0 (December 2013).
It turns out the X100S raw can be processed with the Classic Chrome Camera Profile co-developed by Fujifilm and Adobe. There is a LR plugin called ExifMeta (OS X only) that edits the EXIF meta data changing camera type from X100T to X100S. No doubt other third-party EXIF meta data editors would do the same job. However implementing this change for a large number of raw files could be inconvenient and tedious unless the process was automated.
Besides the ever-popular suspicion Fujifilm intentionally holds back new Film Simulations to manipulate its customers, there could be an alternate explanation.
Fujifilm Holdings Corporation has a Semiconductor Materials division. Among other things Semiconductor Materials engineers and manufactures Color Mosaic materials... or color filter arrays.
Is it unrealistic to assume the color filter arrays of new camera models have different (or even improved) light-frequnecy bandpass characteristics compared to previous models? The raw demosaicing interpolation algorithms take into account the properties of the CFA. This means a identical Classic Chrome and, or Across rendering might be difficult or even impossible for different generations of CFAs.
Given what happened with the X100S and X100T (no Classic Chrome for seemingly no reason other than marketing) and the XE-2 (Classic Chrome eventually supported with new firmware) it seems both technical and marketing decisions are at play.
It turns out the X100S raw can be processed with the Classic Chrome Camera Profile co-developed by Fujifilm and Adobe. There is a LR plugin called ExifMeta (OS X only) that edits the EXIF meta data changing camera type from X100T to X100S. No doubt other third-party EXIF meta data editors would do the same job. However implementing this change for a large number of raw files could be inconvenient and tedious unless the process was automated.\
Dante
+1
From a general embedded firmware perspective
If they got the room to fit the code..it will be a product management call.. Typically this would go to sustaining engineering to handle the older cameras. There is only so much allocated in the sustaining budget. It tends to be evaluated on a case for case basis... Which would then govern which older cameras needed retesting and a priority given to getting it fixed.
There is enough differences in the digital process path and the CPU evolved in the older models, that this would most likely not be an easy change.
Really hope it comes to the x100t. Love the idea.
But now you're talking 'work'... I want to just push one button. 😛
