X100: question about firmware upgrade
wallace
6:14 PM
Germany
I have just purchased a X100, built in 2012, hardly used, with it's original firmware. I want to upgrade but I don't know: Do I have to install 1.30 before I repeat with 2.0 or can I go directly to 2.1 from 1.0?
Thanks,
Thomas
You can just install the most recent firmware and skip all previous versions.
The camera is greatly improved by the 2.1 firmware.
Just make sure the battery is topped off before you start the installation. I assume you will be using the SDHC card method. If so just format the card before you copy the firmware and then format it again after the update. The update file must be copied to the top of the card's directory tree.
