XTOL & Fuji's Acros
Photon42
burn the box
6:11 AM
Neutral Zone
what's the word on this couple? Dev chart says 9 1/2 min @ 20 deg C for 35mm. Anyone tried this? Can I assume the same time for a 120 roll?
Thanks and regards
Ivo
What dilution????????????? 9 1/2 minutes sounds right for a starting place with 1:1 dilution.
I'm using Xtol 1:3 for HP5+ in a Jobo tank with continuous agitation for 10 minutes. I love it! I put my first roll ever of Efke R25 120 through Xtol 1:3 + Rodinal 1:100 last night. Preliminary findings look promising.
Where's Todd.Hanz? I think he has 120 Acros and Xtol wired.
ps: The Kodak data sheet for Xtol (downloadable PDF file) lists modern T-grain ISO 100 films in the 9-10 minute range. You can get the old data sheet with 1:2 and 1:3 times in German here:
http://wwwfr.kodak.com/AT/plugins/acrobat/de/professional/xtolEntwickler.pdf
and more Xtol info here:
http://www.covingtoninnovations.com/xtol/
Good stuff. Use a lot of it!
sorry - totally forgot to mention 1+1. Fuji data sheet only mentions XTOL stock dilution. So I guess I take the plunge with 9 1/2.
I quite like Neopan 400, so I thought I give the 100 a try. Let's see when I find time to process the roll.
Thanks and regards
Ivo
