Yashica GTN light seals
iandg
Iggypops
6:27 AM
Hi all, does anyone know where i can get my hands on a light seal kit for my GTN im determined to get this baby up and running.Thanks
Ian
Go to ebay and search for the seller name "interslice". Jon Goodman is the actual name behind the light seal kit. He has a kit of 9.99 that is great. Without any prior experience I've successfully replaced the light seals on four cameras, including a GSN. Great kit, fast service, excellent instructions. Also check out http://www.kyphoto.com/classics/sealreplacement.html which has his instructions online.
Yes, his kit is very good. I like the tool especially. I got the cheaper kit, which is enough for at least 5 GSNs...make sure you use a very sharp knife to cut the foam, otherwise the foam with roll up and stick to itself. I find it easier to start cutting from the paper backing side (not the foam side).
Great advice to start on the paper side. A metal ruler comes in handy too. I also found that scissors worked well for the shorter pieces.
GTN light seals
GTN light seals
Thanks all, problem solved will be bidding or BIN a kit tonight just hope i dont make a hash of it as i have a QL17 that could do with new seals too.
Thanks again.
Ian.
