Yashica Mat 124- Trick it out with RZ67 screen?
benji77
@R.F.F
5:56 PM
I have been contemplating to swop out the original Yashica Mat's screen for a RB/RZ67 screen for sometime, and I think I will do it this year!
Would anybody be able to share if this is feasible and has done it before with feedback on results would be awesome.
thanks!🙂
Make sure your mirror is in good shape, too. I've replaced some mirrors on personal cameras and for other people and it has made a good deal of difference if the original is corroded or has been poorly cleaned in the past (scratches).
There is a good vendor on ebay, $11 shipped or something in that range so very affordable. (no connection)
Oh, I never thought that the mirror could be the cause of the poor clarity too. The current screen would need a massive CLA, and with that I thought I would might as well go with the screen upgrade. It would then bring the cost of the whole camera similar to a Rollei 3.5. Which I think would be a good comparison in terms of weight/cost/quality as compared to forking out cash to buy a Rollei 3.5, and risk incurring the wrath of the Missus.
Yeah do it.
I'm always most concerned with the carriage in the Yashicamat.
The mirrors get dirty but clean up well.
Occasionally one "de-silvers".
I've had the transport carriage crunch out on two of those cameras over the years.
Mamiya screens are not difficult to self modify. There is a video tutorial online somewhere.
Definetly a good replacement and relatively cheap.
Thank you for the tips guys.
I might just try this at home! LOL. I don't think i would know how to adjust a new mirror for the camera, but after a Youtube clip where someone changed the screen, I think I might be able to change the screen on my own. I am more concerned about the accuracy of the focussing though, where I might just ding something along the process.
there's a groove on the top side of the Yashica screen for the metering so I'm not sure if you can transfer the Mamiya screen easily.
Oleson screen is pretty good and inexpensive. I have both split screen and bright screen and prefer the bright one.
i've confirmed my focusing by comparing it alongside my RF camera.
No adjustment for the mirror.
Be careful when pulling the ground glass/fresnel out of the focusing panel as it is easy to scratch the optical pieces or break the little tabs that hold the springs in place. Takes some care to do it well, some small pieces of tape can be helpful as pads. Once you open it up it's obvious what needs to be done.
Lastly, don't forget to clean the back side of the viewing lens, those are usually dusty/hazed too.
I use naphtha for initial cleaning with cotton swabs, then Ronsonol (leaves less residue, cleans up whatever the naphtha leaves), then polish with a lens tissue.
I don't think there's much point? The Yashica already has a fresnel screen..just clean it, the little springs and tabs are really chintzy on Yashicas. The tabs look like they'll tear, even though they're metal - very thin. If the screen of the Yashica is a piece of matte glass and a plastic fresnel sandwiched together like the Yashica D, the RB67 screen, if it's solid plastic, will put the focus in a different place and you'll have to have it calibrated.
Replacing the mirror is a simple operation. There are three metal tabs cast into the body that determine the location of the mirror; no adjustments needed.
Changing screens IS what will usually require adjustments as the focusing surface depends on the thickness of the screen.
The difference between the stock Yashica screen and the Mamiya screen is not huge. Also as someone mentioned the screen needs a cutout for the meter block- a half-circle maybe 12mm wide on the leading edge of the screen. You'll need a way to shape this if you do your own Mamiya screen.
My suggestion: replace the mirror (marty1107 on Ebay is the guy to get it from). While in there, remove the screen and clean- it is a two-piece system so note the orientations and surfaces. Use only warm water and gentle soap on the plastic fresnel.
Think about getting a Bright screen from Rick Oleson. It is comparable to the Mamiya screen, and he will provide it cut, including meter cut-out, and installation instructions.
Wow, awesome tips here. Once I finish this roll inside the camera, I would send this in for a CLA. If my local guys can do the swop for me, great. Else its DIY time!
The camera tech I use replaces screens in TLR's, including Yashica's, with brighter and better ones all the time. Of course he shims them properly so focus is preserved. I'm not sure where he gets the screens - they are probably scavenged from his many other cameras - he considers this procedure a normal part of a TLR CLA and thinks nothing of it.
Apparently native Rolleiflex screens are notoriously dim - an issue with an otherwise splendid camera.
Received my replacement mirror from Martin (eBay) and upgraded screen from Richard Oleson, where I should be sending them off to a local technician for a full CLA and upgrade 🙂
Will update here once completed!
http://www.markhama.com/
been wanting to send my 124-G to him for the longest time but figured I could just buy a 2nd 124-G as backup, lol.
