Your favourite FSU lens+non-FSU body(or vice versa) setup?
nukecoke
⚛Yashica
1:21 AM
By the chill wind of Red Oktober we got more than usual posts in this sub-forum, molodez. I'd like to know: what's your favourite FSU lens+non-FSU body(or vice versa) setup?
Not limited to 35mm RF. Pictures of the setup or results will be appreciated!
Canon L2 RF with Jupiter-12 35mm f/2.8 is a combo I like a lot. The L2's 0.4x peephole viewfinder for 35mm lens has really nice eye-relief. And J-12 is a killer lens for the money: the next tier LTM 35mm lens would cost at least 3 times higher at even slower f/, and you need luck to snatch them before others do.
I'm using my iPad now, will try to supply pictures later.
Bessa R with white j-8 which has focus tab. Worked without shimming. If only R build was as durable as J-8...
Bessa R & my J-3 50/1.5 is my most used & favorite setup. I just finished a roll using the I 26 52/2.8 & it doesn't like very bright sunlight, least with B&W film. I have a J-8, I61ld, & the I 50/3.5 rigid but the J-3 feels the best to me. I wont even think of trying my J12 on my Bessa but my CV35 is a much easier to use lens.
Random walk thru the park with Bessa with J-3 & Ilford Delta 100 film.
Walk thru Old Salem NC. One of my favorite places to walk only 20 mins. from my house. Same set up. Same film.
I love my J-12s. I use them only on my Zorki cameras for now as they have to be shimmed to be used on my Leica.
J 8 on a Contax IIa, Canon IV SB + black J 12 and an I 61 (Panda) on a Bessa R or an M 6.
I had the I 61 ona a black J 8 adapted by Brian Sweeney.
Here's one taken with the Leica M9 and an Industar-61; I got two lenses for a pound some time ago and gave one away to someone in Greece.
The photo was taken at about 3 to 4ft and at f/2.8
And here's the centre of the photo, more or less; I focused on the binocular's strap.
Regards, David
1972 Kiev 4a and 1956 Zeiss Opton Sonnar f1.5 with light yellow filter, shot on Efke 100 film.
When I had them it was a toss-up between a Leica M3 with a Jupiter-3, and a Pentax SV with Jupiter-9.
The lenses and the SV are long gone, now, so all I can answer with is an M2 with a Jupiter-12.
