Just to get the story straight since this praise of Youxin thread has taken a side-step on a question about BP M4 cranks.
On the black paint M4 there are a couple versions of the rewind crank, and the self-time/frame selector levers, even the shutter speed dial. On most of the BP M4s the parts mentioned above are aluminium alloy with the shutter dial being anodised and the camera front levers painted. With the rewind crank usually the crank itself is black anodised with the flip-out lever brass and painted. There is also an [direction to turn] arrow on ALL the original cranks. Earlier BP M4s are the version with black painted brass parts. (as with ‘Leica’, this does not follow the 100% rule, but pretty close)
If the crank/lever is all ‘black chrome’ aluminium - not black paint - and without the arrow it is a later replacement part.
The brass parts are desirable for a ‘collector’s’ camera, original parts are even on later versions still desirable, after all having a BP M4 is usually part ‘heart’, part user🙂 On a well used M4 the original [early] brass-paint crank could have needed replacement (unless really bent out of shape, doubtful), but should be mentioned and a replacement part cost listed. Leica does not have any of the originals, they are rare to find. An M6 or MP BP part, or even the later ‘black chrome’ M4 part is not the same.
On one of my BP M4s more than a few years ago the delicate machined lever grip ring had popped off and I replaced the whole crank with a [same part] crank from a BP Leicaflex SL (anodised alloy crank with brass BP lever).
There are no black paint over silver chrome crank parts, It was either anodised on aluminium alloy or BP on brass. The ‘Black Chrome’ process is from the M5 time and used only on the later (alloy crank) 1974 reintroduced M4s.
BTW: Its been a long time but Youxin did a CLA on a LTM for me and I was very happy; good work, quick turn around, great price, and to have someone that is still regularly doing the work on these cameras is priceless.
