13Promet
^^^ Well, I'm using Nikon CS 9000, and it resolves 3800 ppi, that still makes 8550 pixels on the short end, so unless your D800, which has 4900 pixels on the short end, uses a lens with an MTF=1,75, i.e. outresolves itself almost twice, this can't be done.
According to my real life experience, those figures don't tell the whole truth.
I own and use an LS4000 for scanning, i.e. same resolution of your CS9000.
If I compare such scans with the 35mm film digitalizations which I perform by using a Fuji X-E2 and a Nikkor 60 AF-D, the latter definitely resolves more details.
In the edges/cornrers such difference gets dramatic.
In this case I'm comparing 5650 pixels of the LS4000 (@4000 dpi) on the long side to the 4900 from the Fuji, so of course less of a gap than your example.
Still, it says something I guess.
I'm not sure whether it depends on the lens sharpness, its DoF, aberrations, film flatness, focus accuracy, sensor quality or whatever, but the actual resolution difference in favour of the less Mpx solution is definitely there.
Unfortunately, film scanner technology hasn't moved nearly as much as digital camera sensors.
In fact, both you and I are using 10 years old scanners.
And I guess that an actual camera lens is not comparable with the tiny one you can find in our scanners.
And of course I'm referring to digitalization of film.
I expect that shooting the same exact pic with a 90mm lens on 100 ASA film then scanning it would result in even more actual resolution difference in favour of the equivalent natively digital solution (X-E2 + Nikon 60mm) due to the additional conversion step from the former solution.
This said, I keep shooting film and scanning because I like it more and don't need zillion of pixels in my files 🙂
