pb908
I have did modification on 2 jupiter-8 : cleaning, shimming & collimating, (thanks to Brian Sweney !! his pdf file helps a lot). at the end I get one GREAT copy of this lens (after swapping some lens element with the other), and one junk lens which both already collimated perfectly.
a friend of mine is offering me kiev (??) with carl zeiss opton 50mm f2 sn 8233xx (6 digit), and CZJ 85mm f2 SN??, jupiter 12, and one 53mm f1.8 (??) russian lens.
from what I heard, Jupiter-8 LTM is "exact" copy of zeiss 50mm sonnar. I wonder if I can get the Opton 50mm f2 zeiss only and use it in my junk jupiter-8 body.
I have googled around and found that Brian Sweney as well has done that conversion several times. my worries is I don't know if my friend's Opton lens can be mounted to Jupiter-8 body. any body know if my friend's opton serial number can be use ?
thanks for your reply! Brian, can you share more about this ?
