Zeiss too contrasty? Issues with shadows.
drjoke
1:02 PM
ZM Sonnar 50mm was my favorite lens for a good part of this year. However, when I try other lenses with lower contrast, I seem to be able to get more details out of the shadows area of my slides.
This is especially true when I use high contrast film like Velvia; it seems that the ZM doesn't do too well in comparison to lenses with lower contrast.
I have no problems with lower contrast films like Provia though.
I read somewhere that high contrast lenses are supposed to bring out more details in the shadow areas, since it recognizes and pickups more details. I also have read the opposite as well. Now I am not sure what to believe.
Yes, a contrasty lens will give a shorter tonal range with a high-contrast film. Apparently in the 1950s some peple preferred uncoated lenses with Kodachrome to 'fill' the shadows (with flare, of course).
Using made-up but believable numbers, imagine a scene with a contrast ratio of 64:1 and a film that can convincingly record a contrast ratio of 32:1. If the lens has a flare factor of 2, then the scene can record more or less 1:1 on the film. If the flare factor is lower -- unity, for an easy example (LF can come close to this) then you will have to sacrfice either shadows or highlights.
Then again, I'd dispute calling the lens 'too contrasty', as I do not believe such a thing is possible. Overly contrasty films (overdeveloped mono, short-range tranny) are another matter.
Roger
