U
Unregistered
Guest
I have this Zorki 4, and the fine focusing lever under the rewind knob just flops around. Is this normal? I wonder why it should be so lose. Once I fine focus the view finder using this lever, the vibration from the shutter then throws in out of focus. Maybe I should shim this with a bronze washer-spring or something? Is there an adjustment I can make by taking things apart? Thanks.
