colyn
ישו משיח
I bit the bullit tonight and bought a Zorki 4 on ebay. I noticed that most of the 4's listed had much of the shutter speed numbers rubbed off and was wondering if anybody knew how to renew or replace the numbers..
I plan to CLA the camera and maybe paint it before trying it out. Also should I replace the Industar-50 50mm f/3.5?? Or is this a good lens??
rbiemer
Unabashed Amateur
Colyn,
Try this:
SHUTTER SPEED DIAL(CLICK)
The I-50 lens may not be as glamorous as a Jupiter-8, but it is in my opinion a fine lens. I use a collapsible one quite alot on my Zorki and FED.
If you can live with the slow f3.5 aperture, I wouldn't be in a big hurry to replace it.
Rob
Try this:
Rob
comp_wiz101
Compulsive Tinkerer
Wow, it's nice to know that my effort is still carried on!
Max Power
You shouldn't have a problem with the Zorki 4 shutter speed numbers. They are engraved as opposed to painted.
Kent
Kent
Screwy
All the gear no idea
Max Power said:You shouldn't have a problem with the Zorki 4 shutter speed numbers. They are engraved as opposed to painted.
Kent
The early Zorki 4 shutter speeds are engraved but the later ones are screen printed , Not to sure of the dates but my 55 has the engraved dial and my 66 also but I have a 64 spares camera that is screen printed
colyn
ישו משיח
colyn
ישו משיח
comp_wiz101 said:Wow, it's nice to know that my effort is still carried on!![]()
I'm glad you did all the work so I wouldn't have to..
comp_wiz101
Compulsive Tinkerer
Well, that's why I figured on posting it
Ash
Selflessly Self-involved
The exposure counter is rubbing off on my 4k. I use a collapsible I-50 and think its a brilliant lens. Check my gallery and you can see the difference between an I-50 and a J-8. I think I picked up excellent versions of both lenses.
I-50
http://www.rangefinderforum.com/photopost/showphoto.php?photo=39492
J-8
http://www.rangefinderforum.com/photopost/showphoto.php?photo=37403&cat=6182
Not the greatest photo's in the world, but theres a bokeh comparison. Dont trust the contrast on the photo's as they've been photoshopped slightly
I-50
J-8
colyn
ישו משיח
comp_wiz101 said:Well, that's why I figured on posting it![]()
Do you know of a source where I could get instructions on servicing this camera?
I've overhauled many cameras but never a Russian one.
comp_wiz101
Compulsive Tinkerer
http://rick_oleson.tripod.com/index-131.htmlcolyn said:Do you know of a source where I could get instructions on servicing this camera?
comp_wiz101
Compulsive Tinkerer
Also, if you need to, the shutter speed dial is held on by two screws from below, inside the top cover.
colyn
ישו משיח
comp_wiz101 said:
Bookmarked...
Thanks
comp_wiz101
Compulsive Tinkerer
Sure no problem, everyone on the forum has always been friendly and helpful to me, so I'm happy to return the favor
