cosmonaut
Well my new Russian Aunt brought me a gift from her recent trip home. A Zorki 4K with a 50mm lens. The finder isn't the easiest to focus. Even when focused it seems slightly blurred. Is this normal? Also what quality with the 50mm 3.5 give me? I have a screw mount Leica 5cm I can use on it if I choose. I thought about using with my Voitlander 15mm and focusing wouldn't be an issue.
OpenWater
No, it isn't normal. My 4K's rangefinder is very clear and shows focus easily. I think you have an Industar 3.5 - a copy of an Elmar 3.5. It should give you excellent results. Here are some samples with my J8 on my Zorki 4K. It sounds like your camera needs a CLA. You'll find many other examples in the International Commie Day - May 1, 2009 Flickr group.
http://http://www.flickr.com/photos/22121746@N06/3496787023/in/set-72157617551971685/
xayraa33
rangefinder user and fancier
"Even when focused it seems slightly blurred"
have you got the diopter focused to fit your eyesight, via that little lever by the rewind knob?
cosmonaut
Yes. I found it thanks.......
ethics_gradient
Could it be the vertical alignment? My R3a is ever so slightly out of VA and it makes the RF patch a bit blurry since the images will never overlap exactly.
dll927
Does anyone know what earth-shaking development caused the M-series Leicas, etc. not to need the eyesight adjustment when all the LTM ones had it? It must have been some technological breakthrough, because I doubt if human eyesight changed its practices.
xayraa33
the Leica II never had it, and also a lot of the japanese Barnack copies also omitted it.
Roger Hicks
Too difficult/expensive/bulky to install. A very old 'breakthrough'.
Brother Joe
Just Joe
Not to hijack this, but, I've got a FED 2 and I've been thinking of adding another USSR Rangefinder, likely a Zorki 4K, since I like the shutter/wind cock over just turning a knob. How does it compare in size to the FED?
Rough comparison makes it seem that they're nearly the same, with the Zorki being a bit larger. The Kievs all seem to be larger and the smallest seems to be the FED1/Zorki1 or the Mir. Does that sound about right?
As far as Zorki's go, is the 4K a decent reliable choice if one gets a nice one (I figure I'll get it from fedka).
Thanks
J
Thanks
J
xayraa33
J
the Mir is a Zorki 4 without the slow speeds, but it still is the same size as the Zorki 4.
