Zorki 6 painting?
cking
out of focus
8:00 PM
Hello all,
I’m still awaiting the arrival of my Z6 from across the pond. I've been browsing here a lot lately and it seems the painting bug has bitten me. Here’s my question to all that have successfully painted their own cameras.
Do I (or is it recommended) to do a full tear down i.e.
http://rangefinderforum.com/forums/attachment.php?attachmentid=909&d=1092058873
Or should I just follow these instructions for top plate removal
http://muj.proit.cz/roman/z6disass/
And then follow w3rk5's instructions for taping everything else off
http://www.yevglad.com/repaint/Paint...ions_Final.pdf
I can see the advantages of doing either, but what’s going to give me the best possible result? The painting won’t be an issue; I’m just more concerned with reassembly of a full tear down. I’m very mechanically inclined; Its just that I have never taken a camera apart. Are the Zorki's easy enough to try for the first timer or should I just get a non-working one to test out first?
Thanks all
edited for spelling and grammar :)
Thanks for the quick response G-man, I've never thought of it that way, typical of me always over thinking the obvious and easiest solutions.
Could I use a Z5 body and transfer the back and rewind lever over? There’s one in the classifieds that needs work. Thanks
Hi cking. The answer really depends on how deep you want to go. Since you mentioned that you have some concerns about reassembling, a full tear down might not be the way for you……..yet. :p
I think either method will give you an excellent finish. You just have to be a little more careful if you do it the way I did.
For example….make sure the tape is adhering/sealing properly or else you’ll get overspray.
I wouldn't go to the complete tear-down if I didn't have previous experience. I'm sure you can make a great looking camera even by just taping what can't be removed. Look at my Zorki and FED in thread "Zorki 4 project almost finished".
PS: Also, don't forget to remove the tape about 15 minutes after the paint job is finished :)
