SCOTFORTHLAD
Slow learner,but keen!
Can I take for granted that this lens is a good option for general use,and is as excellent as the other Zuiko lenses?
I have enjoyed this focal length a lot in the past,and now with four grandaughters under six some head and shoulder pictures would be good.
I don't want to spend a lot so the shorter telephotos are out,and I assume that with some searching, this model would be available at a reasonable cost.
Any comments would be gratefully received.
Thanks,
Brian.
PS.I almost forgot,another grandchild expected this month
,by all accounts this should be a little boy,but you never can tell.
Thanks,
Brian.
ferider
Congrats on the next grandchild !
The 135/3.5 is one of the better Zuikos, IMO. Very sharp, and tiny.
I use the 135/2.8 more often though since you get noticably more shallow
DOF for portraits. Also not too expensive on the used market.
Best,
Roland.
Best,
Roland.
Chriscrawfordphoto
Real Men Shoot Film.
Scott, I have two of the 3.5 Zuiko 135's. Excellent lenses, very small, built in lens hood. I also have the 85mm f2 and the 100mm f2.8. I think the 100 f2.8 is a little sharper and easier to use for portraits as it focuses closer than the 135. I got my 100 for $60 on ebay. The 135 may be even less though and it is still an excellent lens.
wray
Chriscrawfordphoto said:Scott, I have two of the 3.5 Zuiko 135's. Excellent lenses, very small, built in lens hood. I also have the 85mm f2 and the 100mm f2.8. I think the 100 f2.8 is a little sharper and easier to use for portraits as it focuses closer than the 135. I got my 100 for $60 on ebay. The 135 may be even less though and it is still an excellent lens.
Thanks for the information. I just got an OM2 (back to the future for me) and have an OM2s on the way. Now I'm on the lookout for some medium teles.
Trius
Waiting on Maitani
$60USD for a 100/2.8 is a very good deal. That said, the 135/3.5 is one of the best bargains on the market. Very sharp from all accounts, and small/easy to use. Having both is never a bad idea.
yaadetgar
Hi!
I just bought an OM2 on ebay, with several lenses and I was thinking about the 135mm also...
I think I may have it, just after I'd have more 'budget'.....
Yaad
Yaad
oscroft
Yep, the 135/3.5 is a cracker (and can be had really cheap). The only reason I don't use mine very much is because I also have a 100/2.8 and prefer that focal length - but in terms of quality I doubt I could distinguish between them.
SCOTFORTHLAD
Thanks everyone for taking the time to advise---these are pretty consistent and ringing endorsements for this lens and the 100.
I will be checking out the local camera shops to see if maybe one is laying on their used equipment shelf.
Brian.
Brian.
SCOTFORTHLAD
SCOTFORTHLAD said:Thanks everyone for taking the time to advise---these are pretty consistent and ringing endorsements for this lens and the 100.
Brian.
Called in to the local camera shop on the weekend.Unfortunately they couldn't find me a Zuiko 135,but found two Zuiko 75--150 zooms on the shelf.Pretty neat and compact they were too.Undoubtedly larger than a 135 would be,and probably not as sharp etc.,but more versatile.
More expensive too.Left them there,---it's 'thinking about it' time.
Anyone had any time with one of thesel little works of art.
Brian.
DeeCee3
Want to Go International??
This thread on Zuiko 135s got me interested. I checked out the KEH website and if you don't mind sending some Sterling currency over here to the Colonies, that Atlanta store has a DEAL on them!
Just a heads-up...
dc3
Just a heads-up...
dc3
plummerl
Actually, according to some tests (http://members.aol.com/olympusom/lenstests/default.htm), the 75-150 is as good or better than the 135 f/3.5. It is only about an inch and a half longer (same diameter). A very nice lens!SCOTFORTHLAD said:Called in to the local camera shop on the weekend.Unfortunately they couldn't find me a Zuiko 135,but found two Zuiko 75--150 zooms on the shelf.Pretty neat and compact they were too.Undoubtedly larger than a 135 would be,and probably not as sharp etc.,but more versatile.
Anyone had any time with one of thesel little works of art.![]()
Brian.
Trius
Waiting on Maitani
Yup, that zoom is quite good. The ultimate Zuiko zoom was the 35-80/2.8, but it goes for silly money.
