When I sent my early m6 to leica for repair the Lietz red dot was Removed and replaced with Leica red dot. My pal says it changes the
collector value? is that really true?
To calibrate the M6's rangefinder removal of the dot is necessitated; I guess they just found it easiest to put a new dot on as opposed to preserving the original Leitz one.
I'm not sure on the value of this slight anachronism, though.
Was your early M6 collector grade to start with? Mint? Boxed? If you've been using it to take pictures, probably not. It probably doesn't make much difference.
Don Goldberg did that OK with my early M6, but in answer to the OPer's OP, I don't think I'd worry at all about collector value. Even never-opened-still-sealaed-in-the-box-we-had-to-Xray-the-box-to-prove-there's-a-camera-in-it M6s don't collect that huge a premium.
