Only that you had to tip the whole room over by 20-30 degrees so that it wouldn't fall over!
You see, there's this thing called centre-of-gravity. It's generally going to be somewhere near the middle of the camera (and further forwards, the heavier the lens becomes). NOT all the way over to the right.
For the camera to be stable, the CG has to be above the triangle formed by the points of contact of the tripod legs (the "triangle" being a projection onto a plane perpendicular to the gravity vector and "above" meaning that the vector of the force on the CG passes through this triangle.)
Having the tripod mount all the way over to one side means that you need to use a much larger and/or more massive (heavier) tripod than would otherwise be necessary (connecting the tripod to the camera moves the CG, of course 🙂 ).
Hope that's all clear now 🙂
colin
