furcafe
The pre-war II/III do have a more durable RF, basically almost impossible to knock out of alignment, but the IIa/IIIa are pretty tough, too, @ least more so than Leicas. You will find the occasional IIa/IIIa that will be slightly vertically misaligned, but that's usually due to the camera having been exposed to hot conditions for a long time, allowing the pitch (glue) that holds the RF assembly in place to soften & shift a bit (the II/III aren't vulnerable to this as their RFs aren't secured by pitch), not the result of shock or vibration per se.
rxmd said:Hi Pherdinand,
Doesn't the postwar IIa/IIIa have a different rangefinder setup that is easier to knock out of alignment?
Talking about Contaxes, another recommendation would be to buy a good, $50 or so Kiev and try it out for the ergonomics, and if the camera works for you and you still want the original (unlikely enough IMHO) to go looking for a Contax.
Philipp
