Sensor cleaning
wwulfsohn
11:52 AM
I just went to clean my sensor on my new m8 with a sensor brush. In the process, I noticed small smudges on the sensor (while looking at it in bright light). I have never before cleaned or touched the sensor. It must have been delivered this way.
Should I buy a sensor cleaning swab kit or leave it? I have not noticed any distoritions in my image.
Sooner or later I imagine you will have to clean the sensor with a swab kit. ( I just did it today for the first time).
Honestly, If I where you I would clean it with a good quality swab kit. If they dissapear look again after some camera use. If they do not go away or appear again I would get my camera serviced by Leica as fred sugests. But I would try wet cleaning first.
wwulfsohn said:
Just a faint surface pattern which you can only see in bright light.
Are you sure you're seeing some contaminant on the surface and not the normal diffraction or interference pattern that the sensor manifests when directly illuminated by a light source?
I just cleaned the sensor with a dual swab (wet and dry) system from Green Clean. The sensor is now looking great and perfectly clean.
Thanks for the help.
Bill
wwulfsohn said:
Tnanks - any swab kit recommendations?
Yes, "Eclipse 2" with "Sensor Swabs".
I clean at least ones a month now (M8 with over 5000 picts).
At the beginning, the shutter throw a lot of grease onto the sensor, i had to clean ones a week, but it calms down after many shots.
Good, I am sure you will check after some shooting. If they come out again (hope not) the shutter must be spraying something. In that case I would not touch it any more and send it to Leica (if your dealer does not exchange it).
