seany65
Is it a good idea to change the brightness of the evf/lcd so the image is as close to what you see in reality, or to leave the setting at "0" even if the evf/lcd is rather brighter than life at that setting?
Thank you Joe and boojum for the replies and the info. I've seen several battery/charger combos being sold as "for" or "comaptible with" fuji NP-95 and was generally considering only using the batteries they come with in those chargers. Some seem to only come with usb cables and some come with wall plug cables, and most of them seem a little too cheap for comfort, lol. On top of that, many batteries seem to have a higher "mAh" number than the fuji np-95, eg 2100mAh compared to 1800mAh so ther's that adding to the worry. I presume the 2100mAh batteries wouldn't be fully charged by the fuji charger as it would be working with the idea that the battery has a mAh number of 1800?
I have used manufacturer and generic batteries (when available) for whole bunches of cameras. In general, the manufacturer supplied batteries last longer per charge and remain serviceable longer.I use generic batteries and chargers. For Leica and Pentax I use company chargers and generic batteries. Sony allows generic batteries and chargers. All have worked well so far. HB is their battery and their charger. That's all there is. There is no problem getting either, however.
And what, pray tell, is wrong with hitting the stuck battery with a hammer? 🤔
Thanks to everyone for the further replies and info.
If you're planning a trip into the heart of Borneo, perhaps. Otherwise, no.Is there any point in buying one of those little silicon/rubber jackets for a camera?
About as much as the typical thin iPhone case affords an iPhone. 😉Is there any point in buying one of those little silicon/rubber jackets for a camera? Do they offer any protection?
