Uncle Bill
- Local time
- 7:50 PM
- Joined
- Apr 25, 2005
- Messages
- 1,077
I am toying with playing with Xtol, I am curious to hear the good bad and the ugly on this developer.
Freakscene said:Given the usual criteria (fine grain, sharpness, good tonality) Xtol is the best commercially available developer for 35 mm film. It uses an ascorbate and a phenidone derivative as developing agents. This means it works at high dilutions. If you use Xtol and don't experiment with dilutions you are doing yourself a disservice. Ascorbates have development by-products that are development restrainers - this leads to excellent compensation (and not just through dilution). It also has a buffer as its major alkali, meaning it operates at a lower pH, which encourages finer grain.
http://leica-users.org/v35/msg07982.html
To avoid having it go off, mix it with distilled water and fill small bottles from your 5L batch. If you completely fill them and store in the dark they will last 12 months +. You need to use distilled water of known quality or it can oxidise quickly.
The link I've included above has some do-it yourself formulae that replicate Xtol and several of which last almost indefinitely.
Marty
This looks very good to me ! I have just bought a 5l package of XTOL but not tried yet (Have to use the D76 first) Quite keen to see how XTOL will work with Tri-X (pushed to 800) In the above photo, was the Neopan rated @ true 1600 ? How often do you agitate the tank ?mr_phillip said:
