DeeCee3
Look Again...
Look Again...
If you'll note the first frame attached at my initial post, and to a lesser degree the other one, too, you'll see that the "ghost" does not really have a straight edge. I think one side of it may be fairly straight but the other side has a definite "bow" effect to it.
I live out in the boondocks and the nearest hobby store is 50 miles away but I'll pick up a small bottle of Floquil engine black and a rigger brush next time I venture out of the mountains, and see if that won't fix it.
Meantime, I have another 35mm lens I can use...probably not as good as the Jupiter 12 but acceptable.
Again, thanks to you all.
dc3
Look Again...
VinceC said:Still not clear how a round lens element would make flat, straight-lined, straight-edged flare.
All the flare I've ever seen is circular or in some way rounded.
dc3
