crawdiddy
qu'est-ce que c'est?
I keep checking this thread to see if Tri-X will finally edge out HP5+.
*edit* Yes, Tri-X now leading.
charjohncarter said:nikon_sam, check with John Sexton and as someone said 'he may know a thing or two.' His latest email was about the 'new' Tmax400, and he recommended: D-76, 1:1, 68 degrees, 7 minutes. He also, I believe uses Tmax RS and D-76 on the old Tmax400. I'm with you though, I just couldn't get the stuff to work for me. Frankly, I'm surprised at how many votes Tmax400 got. I wish these guys and gals would tell us their secrets.
Sorry, (this is an edit) he uses E.I. 250 with the new Tmax400.
charjohncarter said:Chris, I did read in one of Sexton's (about old Tmax and possibly Tmax400 medium new) missives that he used 75 degrees, but he said that it was because he couldn't get water temperature lower where he lived. Just by coincidence Kodak also recommended 75 degrees for Tmax development.
Russ said:I forgot to mention, that for whatever reason, Neopan 400 negs, print up quite well on color paper in the one-hour photo machines. The Neoapn 1600 (very nice film) prints up poorly on one-hour color machines...
Russ
Suggest undiluted Adox ATM49, if you can get it in the States. I've been using this for a while with HP5 and in my opinion it's perfect.feenej said:Not to sound like a broken record, but Neopan, TriX and HP5, in that order. I have not had good luck with Rodinal or Diafine with the 35mm version of HP5, so I am looking for a better develper for the 100 feet of it that I have on hand right now. I wish Neopan was still available in bulk.
As I've just mentioned, Adox ATM49 undiluted gives wonderful, smooth results with HP5 and also with Tri-X without the speed penalty of Microdol or Perceptol.thomasw_ said:Obviously we have a strong majority of trix and hp5+ users; but i wonder whether many of them use any of the more solvent developers; e.g., microdol x at no greater dilution than 1:1, Ilford Perceptol, etc.? Some images from this microdol/trix or microdol/hp5 combination seem to have a greater tonal range than with less solvent developers.
