corazon
It certainly doesn't have threads on the inside for screw in filters...but is there another option?
FrankS said:That could be a Series filter adaptor. It could work too, but it connects to the lens by grabbing onto the outer rim of the lens.
FrankS said:If you can't find the proper adaptor, try to find one Summitar filter, any kind even with damaged glass, so you can make your own adaptor by removing the glass and epoxying a filter step up ring to the empty Summitar filter ring.
Okay, but how to know which Series filter holder it is? I assume it's written around the outter edge?FrankS said:If the ad says Summitar filter, it may well be a proper screw-in Summitar thread on one side and a Series filter holder on the other. That would work well.
