Vertical RF adjustment of M5
eric rose
ummmmm, filmmmm
11:40 PM
Canada
Do I need some special tool to make this adjustment? The port on the front is easy enough to get at but I can't see into the tiny hole to see if a normal screw driver would work.
Thanks,
Eric
A normal small slotted or flat head screwdriver works fine. Set the camera lens to 0.7 meter focus or dismount the lens from the camera to get a better view of the screw head. As the cam roller moves forward, so does the adjustment screw.
